Need Help with cleaning the headlights.
Old 03-28-2006, 02:17 AM
KERO's Avatar
Default Need Help with cleaning the headlights.
I've noticed my headlight (the outer cover) is turning abit yellowish. I'm not sure what's causing it. Not sure if it's from heat or what but if any of you know a certain product that'll get rid of it, I'd greatly appreciated. I also have a pair of headlight that's sitting with the same problem with a bit more discoloration. It looks like the previous owner got wax on it, and dried up. Any solution to this?
I'm not sure how safe it is to buff the plastic. Any help is appreciated.
Old 03-28-2006, 07:14 AM
wanabe's Avatar
several solutions...
i always go least aggressive to more aggressive-
the least aggressive is plexus. it is a plastic cleaner which can get light discoloration and will also add some protection.
if plexus doesnt get it, you will need to go to a polish- there are several plastic polishes that will work. always test a small area first- and i use the pc for this step.
a good example of what you can do with headlights is in here:
https://www.s2ki.com/forums/index.php?showtopic=372898
Old 03-28-2006, 10:57 AM
Ubetit's Avatar
I use many of the same polishes I use on paint for plastic and glass.
Old 03-28-2006, 11:18 AM
Filthy Beast's Avatar
Where can you fine Plexus ? I have never seen it sold anywhere.
Old 03-28-2006, 12:18 PM
thetz99's Avatar
here's a thread where I used a pc and 210+ plastic polish
https://www.s2ki.com/forums/index.php?showtopic=296109
before
after
Old 03-28-2006, 12:37 PM
KERO's Avatar
before
after
Thanks for the help guys, I'm going to get me a PC and try this out.
I'm going to try what WANNABE suggested..but going with Plexus if that doesn't work..I'll try what Thetz99 did. Thanks again.
THETZ99 that's amazing!!!!
Old 03-28-2006, 02:27 PM
thetz99's Avatar
You will find that the PC is a FANTASTIC multipurpose tool that gives you the means to get that GREAT showcar look on your S. One warning tho, if you are prone to OCD then you might want to reconsider because detailing can be very addictive
Old 03-28-2006, 02:36 PM
koala's Avatar
Originally Posted by thetz99,Mar 28 2006, 05:27 PM
You will find that the PC is a FANTASTIC multipurpose tool that give you the means to get that GREAT showcar look on your S. One warning tho, if you are prone to OCD then you might want to reconsider because detailing can be very addictive
How hard is it to use a PC if you've never used any sort of power tools for detailing before? I'm used to detailing by hand and it's getting pretty annoying!
I guess the biggest thing I'm always worried about is damaging my paint from applying too much pressure or something along those lines.
Old 03-28-2006, 02:51 PM
Soof's Avatar
koala - nah, don't worry about harming your car's paint with a PC. Just a little common sense will go a long way. I had no experience with the Porter Cable but I knew I had to get one if I wanted the best shine I could get. I very quickly became comfortable with its use and my S looks absolutely great now.
I'd say the thing to be concerned about is pad and product choice. There's some good avice here to help you with that.
thetz99 - Addictive? the use of the PC is addictive? Now you tell me !
thetz99's Avatar
It is almost IMPOSSIBLE to hurt your paint with a PC. In my scary paint chip thread, that was the FIRST time I used a PC and you figure out pretty quick how much pressure it takes for the machine to work properly.
I just recently purchased a Rotary which I have been warned is a whole different animal and must be respected when it comes to polishing. I have a test car that I will use that on before I let it near my S.
Quick Reply: Need Help with cleaning the headlights.
