Mothers mag aluminum vs billet polish?
I've been polishing my SS exhaust piping with Nevr Dull, and I'm noticing anything I polish with Nevr Dull from my ap2 exhaust tips to the exhaust piping is leaving alot of fine scratches on the exhaust piping and tips.
I was wondering if Mothers does the same, and if theirs a difference between the Mag/aluminum polish vs the polish?
Any other tips on polishing the metal would be great, I know doing it by hand won't eliminate all the scratches, but the Nevr dull is leaving tons so anything better would be great.
First, make sure those metal surfaces are clean!
Secondly, turn your rag/applicator/whatever often so that stuck-on grime that comes off doesn't grind into the metal.
Finally, I've had lots of luck with Mother's Mag & Aluminum polish on most metals. A tub of the stuff will last forever - you don't need much.
If you want to get fancy or try to polish out scratches (machine polishing needed), Autosol works well.
