Microfiber Quality?
You will be able to tell the difference immediately if you are using the towel to dry your car after washing it. The higher fiber count will hold more water which means a lot to me. I have one of the "Big Blue" towels from proper auto care and it's great. I just use that one towel to dry all of the water off of the car. You will also be able to tell the difference if you are using the towel with anything that needs to be removed from the finish, like carnauba wax. The higher fiber count towels will hold more residue than the other towels.
Will a higher fiber count towel make the finish look better? I don't think so. Just by picking the towel up, you will be able to feel the difference, since the higher count towel will feel thicker and more plush. Are the higher count towels worth more money? In my book, yes, but I don't think that I would feel justified paying a lot more for them.
agreed - the higher tpi count is reflected in the feel to your skin and the amount of moisture. the manner of processing is also related to the amount of moisture it can hold . .
there are drying specific towels (i have a sample from my supplier) and buffing, removal, cleaning towels.
they are way better than regular towels (IMHO)
and the big word of caution is this . .
be sure the ones you get are Korean made - the general rule of thumb is they are better than the ones made in China . .
for instance, my towels are not in the 150-200,000 tpi count - but i use them fine for polish removal on black - and great. water absorption is excellent also - i suppose it could be better, but the question always remains, how much better, and compared to what and under what conditions - and is it worth it price wise?
[QUOTE]Originally posted by Homer2
[B]and the big word of caution is this . .
Thanks everyone, so at this point in the thread I can assume that the cheaper ones aren't neccessarily worse, but they aren't as good either, meaning that I would be better off buying the slightly more expensive ones, but if in a pinch, the others will give comparible results, although not as easily.
Driv300mph
04-16-2004 06:43 AM
