Meguiar's Wheel Brightener
another great mikeyc review!
just an additional warning - and i want to expand on your warning:
be very careful with this product- acid based cleaners can harm wheels. if too strong or left on a clear coated wheel, acid can etch the wheel. and they can easily damage older noncleared wheels.
my preference is for nonacidic wheel cleaners when possible.
as always... this is my opinion.
[QUOTE=wanabe,Aug 4 2006, 12:01 AM] just an additional warning - and i want to expand on your warning:
I've have this stuff and APC, I wouldn't use it as a regular wheel wash. It is potent stuff. Mos times diluted APC is more than enough and even that is more harsh than i'd like for regular use.
From the above information it would appear this would be harmfull to our OEM AP1 wheels ...
Although the face of our wheels is clearcoated and therefore ok per the above ... it is my understanding that the inside of our wheels ... the "barrel" of the wheel ... is aluminum or aluminum alloy and is uncoated.
Would this not be bad for the insides ?
I would disagree. I purchased a used set of MY01 wheels that were used thru the winters in a region that uses salt generously. The face of the wheel is in good shape because it is clearcoated ... the inside of the wheel (the barrel) is blemmished with mild pitting and discolorization.
I have had some moderate success in cleaning them up with SOS pads and p21s gel. However, they could still use something stronger to "brighten" them ... hence the consideration of the use of Meguar's Wheel Brightener.
However, the comments above about use on uncoated aluminum, which I think the inside of the wheels are, has me having second thoughts about trying this product.
Therefore, I would like someone who has used this on our wheels to comment ... especialy if used on the insides of our OEM AP1 wheels.
I've seen the back sides of a lot of wheels, because I do often take them off to clean the other side. I can honestly say that I have yet to see one wheel that is painted and clear coated on the front, but bare metal on the back side. Plus, I've seen AP1 wheels and they definitely looked painted all around to me.
If you have some sort of documentation that I could read indicating that the back side of AP1 wheels is not painted I would love to read it. Just keep in mind many surfaces are deceiving. For instance our tops looks like they are fabric, but it's vinyl.
I don't know how to link to the original post from "wanabe" in August of 2004 when this subject was discussed ... but here is a link he posted from autopia:
http://www.autopia.org/forums/showth...threadid=42691
