Meguiar's Deep Crystal System (3-Steps)
Old 05-21-2008, 03:39 PM
chris2002's Avatar
Meguiars products do work well. They don't seem to last that long.
NXT is real nice but it seems to last less than a week. Gold Class a little longer. If you can get some Mirror Glaze Yellow Wax, that can last longer.
The older Zymol stuff, $$$, not the stuff in Autozone, used to last a real long time.
Old 05-21-2008, 03:48 PM
EOE
EOE's Avatar
Original NXT yes....
NXT 2.0 been tested to last twice as long, some say up to 15 Washes.
Gold class does NOT last that long, but to top the car off with it does help to get amazing results.
Old 05-21-2008, 08:17 PM
bumblebeeS2K's Avatar
nxt 2.0 is definitely an improvement over the first version. if you want good meguiars otc combo, after polish add two thin coats of nxt 2.0 (allow each coat to fully cure) and top it off with M26 adding extra coats as you see fit.
Old 05-26-2008, 12:39 AM
jchetty's Avatar
Originally Posted by CU Nick,May 19 2008, 02:20 PM
I am looking to do a major detaling job on my S2000 this Memorial Day Weekend. I have been looking for a good polish that will remove light swirls by hand. I came across Meguiar's Deep Crystal Sytem that is a 3-Step process. Has anyone ever used this? What is your take on it? Or is there something else I should be buying instead? I'm skeptical about buying car care products from Pep Boys, Advanced Auto, etc... That is why I'm asking about the Mequiar's products.
Any recommendations?
Step 1 - Deep Crystal Paint Cleaner
Step 2 - Deep Crystal Polish
Step 3 - Deep Crystal Carnuba Wax
that polish won't remove light scratches If anything it will fill them in. Removing scratches is an art. Light scratches can be removed by hand using the combination of right products and techniques. If your light scratches in an isolated area of you S2000 and you want to stick with Meguiars, I would recommend Scratch-X. If you're talking bout the whole car, doing by hand is difficult and time consuming It def looks likes there are some knowledgeable detailers here that would be a better option. If you must go at it by hand, I will give you a hint. Don't do the whole car, you will rush and it won't do any good. Do a few panels a month and a few months your car should be ok More importantly, when I was detailingl I would tell people this---Its more important, easier, cheaper, less time consuming to prevent swirls from using proper techniques then to have to constantly remove them
Decz101
02-16-2015 09:03 AM
Jaeden09
03-02-2011 05:11 PM
starchland
03-25-2009 04:54 PM
s2ksimon
06-18-2004 03:49 AM
dierk
08-09-2002 09:07 AM
Quick Reply: Meguiar's Deep Crystal System (3-Steps)
