Lubricating door and convertible top hinges
Hi, guys. My door hinges are starting to look pretty grungy, so I thought I would clean them with some APC+ at my next wash. I have never lubricated them before, and I suppose that I should lubricate them after I clean them right? What should I use? White lithium grease? Silicone spray?
Also, should I periodically lube the various hinges of the convertible top? If yes, what should I use?
TIA.
Al
TIA.
Al
https://www.s2ki.com/shared/library/...-023/index.htm
for the top, you can look at the TSB to see what lubricant to use and where to apply it. i would use also use white lithium grease for the door hinges. careful while applying the white lithium grease, it will splatter so keep the interior covered.
I use this over white lith grease. it doesnt make such a mess white lith does and works great!!!!!! no wonder why its like 20 something bucks a can!
Originally Posted by krshultz,May 7 2009, 06:11 PM
Where did you find that stuff? Wurth makes some really excellent products. Trouble is, I can never find them.
