lithium grease on my soft top
I got some lithium grease spray on parts of my soft top (interior side of it). what can i do to remove it? theres whites spots everywhere.
also can i just use an interior leather cleaner to polish some of the lithium grease off my seats as well?
for the leather, a good quality leather cleaner should do the trick. be sure to follow that up with a good leather preservative (townsends is my fav, and lexol is good too)-
by the way- on the inside of the top be sure to try a small area first with each product before doing the whole thing... you can see how it works and make sure it doesnt make it worse.
If the above suggestion doesn't work for removing the grease from your softtop, I would use a 50/50 mix of isopropyl alcohol and distilled water to remove the grease. Spray a small amount onto the area, and agitate with a brush (toothbrush will work). This has been the only thing that's worked for me when removing stubborn polish splatter from my softtop
Originally Posted by wanabe,Feb 9 2007, 09:14 AM
good suggestion, and i forgot the brush suggestion which is an important part of this!!
