Just got my order of Klasse AIO
Old 03-10-2006, 12:39 PM
superjimbo's Avatar
Default Just got my order of Klasse AIO
I purchased a bottle of Klasse AIO, a pair of sonus polishing towels, and a couple foam applicator pads from autopia.org. What's the best way to apply this stuff? How much of this stuff will I need to finish my car? What sort of technique do you guys use when applying it? Do I need to use any force when applying it or should I just glide it on with light pressure? Any techniques for buffing this stuff out? Sorry for all the questions...first time user of this stuff and I'm just trying to soak up all the information I can. Thanks!
Old 03-10-2006, 12:47 PM
Emil St-Hilaire's Avatar
One of the easiest to apply.
Just glide it on with light press.and wipe it off;don't even have to wait.
And follow it with a few coats of P21-S.
Old 03-10-2006, 12:54 PM
superjimbo's Avatar
Thanks!
Also, how much should I be using? And how often should I be switching applicators?
Old 03-10-2006, 04:58 PM
Use very little at a time,and change applicator,when it gets dirty.
Old 03-10-2006, 05:35 PM
frank b's Avatar
Great stuff! Very easy to apply and remove. As Emil said, try not to use too much. A very little goes a long way. Enjoy.
Old 03-10-2006, 07:35 PM
moonsurfer's Avatar
I usually spray a little quick detailer on the applicator before applying to allow the Klasse to spread more evenly as well as use less product.
Old 03-11-2006, 06:00 AM
NNY S2k's Avatar
Your going to like the results and ease of use.
Old 03-11-2006, 08:54 AM
RBR
RBR's Avatar
Do as Moonsurfer said, wet the pad some with some quick detail spray, makes it much easier to apply. You'll love the results.
Old 03-11-2006, 09:56 AM
superjimbo's Avatar
yay - I'm excited to put this stuff on...just gotta wait for this damn rain to go away
In case any of you are interested I found a greay tutorial on how to apply this stuff:
Click!
Old 03-11-2006, 01:29 PM
jonw440's Avatar
My Wife does crafts.When she gets done with her paints(2 ounce) I wash them up and put the AIO and HGSG in them. This is a good way to see how much you are applying.
I find one ounce is just enough for your average size car.
I apply the AIO by wiping on one section, then wipe it off before it dries.
The HGSG likes to sit for at least an hour before removing.
The AIO likes a damp applicator and the SG likes a dry applicator.
If you own a PC apply them both with it.
IF you have any streaks from either the AIO or the SG rewipe the streaks with a damp Micro fiber towel, then imeditaly wipe with a dry MF towel.
You can also spritz the streak with a detail spray. I find the damp-dry towel trick works the best.
Quick Reply: Just got my order of Klasse AIO
