its happening, headlite haze!
how can i fix this short of new headlites. i tries some plastic polish a friend had, but it didnt touch it. its forming right at the top of the lites, it looks like my car is trying to grow eyelids, not good. anyone else had this happen. thanks!
I work on airplanes for a living, and once in a while we have to polish off scratches on the cockpit windows. We use a Micromesh kit, which has sandpapers starting from 3000 or so sandpaper all the way up to in the 6000 range. I really does wonders for the acrylic windows. I guess you could use this on the headlighst also. Just my 2 cents.
I've heard nailpolish w/o acetone works. Never tried it myself. I actually just used high grit sand paper, wet sand, then dry, then polish with PC on my van. Started with 1000 grit wetsand, then did 2000, then 4000, then dry and polish.
They sell headlight polishing kits at advance auto/autozone that I used on mom's 1994 merc. I think it was about 15bucks. Worked extremely well. Just a pad you add to a drill and spray with water.
