How u fix them yellow head lights?
Well i got a 2000 s2k and the car is mint except for them lights(headlights), their getting yellow (especially on the top of the headlight) Does anyone know how to fix this?? i tried wet sanding it and it worked but now the light looks kind of blurry, i used 2000 sand papper and then i used special wax that you use after you wet-sand, did i do anything wrong??? I mean the yellow's actually not there anymore but now the light looks kind of blurry so im confused!
You can't just use 2000 grit and be done with it, it's a process...1500 grit, then 2000, then 2500, ect...
BTW, The search button is your friend
https://www.s2ki.com/forums/index.php?showtopic=221878
Originally Posted by GranPrix,Dec 29 2007, 07:13 PM
