How To: Stop "Rust Dust" on Brake Rotors After Washing Car
Old 10-07-2013, 07:54 AM
Former Sponsor
Autogeek.net's Avatar
Default How To: Stop "Rust Dust" on Brake Rotors After Washing Car
Have you ever said to yourself "how come I didn't think of that?"...that's exactly what crossed my mind the first time I heard about Hyde's Serum Rust Stopper.
Hyde’s Serum Rust Stopper puts an end to a common problem that plagues every detailer and car care enthusiast after a car wash – rusty brake rotors! Through the use of advanced chemistry, Hyde’s Serum Rust Stopper blankets your brake rotors in a protective film that prevents “rust dust” – the initial brake dust on clean wheels that occurs after washing. Application is as simple as spraying on and walking away!
“Rust” and “detail” are two words that should never be used in the same sentence. Unfortunately, those words go together more often than they should because as every detailer and car care enthusiast has experienced, brake rotors often form light surface rust after being cleaned. Hyde’s Serum Rust Stopper is the solution that you’ve been dreaming of!
How to use Hyde's Serum Rust Stopper
Hyde's Serum Rust Stopper is exceptionally easy to use. Application is straightforward - no lengthy instructions to memorize.
First, start off with a dirty wheel. Check out the heavy brake dust build up on this Pontiac G6!
Wolfgang Uber Wheel Cleaner to the rescue! Wolfgang Uber Wheel Cleaner is a pH-balanced, acid-free wheel cleaner that is designed to remove caked on brake dust and road grime with minimal effort required from YOU. Wolfgang Uber Wheel Cleaner does more than clean wheels - it dissolves iron particles, leaving your wheels squeaky clean. What's really cool is how it changes colors from clear to red as it comes into contact with iron particles. Best of all, Wolfgang Uber Wheel Cleaner is safe on ALL wheel finishes.
Application is as simple as spraying on, letting it dwell for a couple minutes, and agitating with your favorite wheel brush.
"Bleeding effect" shows you that it's working!
After letting Uber Wheel Cleaner dwell on the surface for a couple minutes, I used the Daytona Speed Master Wheel Brush to clean the wheel barrel and in between each individual spoke. The Daytona Speed Master Wheel Brush and its flexible stem with thousands of chemical-resistant bristles make cleaning hard to reach areas a breeze.
To clean the face of the wheel, I used the Montana Boar's Hair 8 Inch Wheel Brush. This particular brush is super soft, making it an ideal choice for scratch-sensitive finishes. The bristles are flagged at the end, enabling maximum agitation.
After a thorough rinsing, it was time to apply Hyde's Serum Rust Stopper! While the rotors were still wet, I applied an even coat of Hyde's Serum Rust Stopper. Any overspray was removed with a Microfiber All Purpose & Wheel Detailing Towel.
This is what your brake rotors would normally look like after washing your wheels....
This is what a brake rotor looks like after Hyde's Serum Rust Stopper was applied....
If you're sick and tired of rusty brake rotors taking away from the appearance of your freshly-cleaned vehicle, pick up a bottle of Hyde's Serum Rust Stopper. This acid-free, pH-balanced solution is safe and effective on all brake systems - over spray will not damage brake components or delicate wheel finishes.
On Autogeek.net
8 inch Montana Original Boar’s Hair Wheel Brush
Old 10-08-2013, 03:30 AM
AE_Racer's Avatar
Excellent post, I have white wheels and everytime I clean my car and wheels, I get a ring of rusty water stains around my inner barrels. How does the Wolfgang wheel cleaner compare to Sonax? I've been using the Sonax cleaner for the past year or so with excellent results but im always open to new products.. Thanks for any input.
Old 10-08-2013, 04:03 AM
Former Sponsor
SONAX Full Effect is a great wheel cleaner (we sell a ton of it!), but I'm more partial towards Wolfgang Uber Wheel Cleaner for a couple reasons:
1. It clings to the surface better, allowing maximum dwell time.
2. It doesn't smell as bad.
3. You tend to use less of it compared to Sonax (this is due to the superior clinging nature of Uber Wheel Cleaner)
Old 10-08-2013, 06:08 AM
AE_Racer's Avatar
I do seem to use alot of Sonax. The 500ml bottles only last me 2-3 cleanings. I just stocked up on it a few weeks ago, once im getting low I will probably try the wolfgang cleaner. Thanks!
Old 10-08-2013, 06:55 AM
Former Sponsor
Enter for a chance to win a bottle!
Giveaway! Hyde's Serum Rust Stopper
Old 10-08-2013, 12:14 PM
psynx's Avatar
stick to sonax, if you wanna try something else
1Z http://www.1z-usa.com/einszett_wheel_care.html makes a good one
and also
scholl makes a good one. I wouldnt recommend WG
Todd actually tested these 3 out check it out if you have time
http://www.autopiaforums.com/forums/...round-1-a.html
sonax vs 1z vs scholl
Old 10-09-2013, 04:24 AM
Former Sponsor
and also
Fortunately we carry all of the above.
Find something you like, and use it often.
Old 10-09-2013, 09:03 AM
ADJUST's Avatar
Great Read, Nice product.
Old 10-11-2013, 05:14 AM
Sylvan's Avatar
I actually like the smell of Sonax, but I did go through a bottle rather quickly.
Old 10-12-2013, 05:47 AM
Former Sponsor
Thanks. Based on customer request, I put together a bundle that includes all of the products featured: Wolfgang Hyde’s Serum Wheel Combo
That's a first!
Quick Reply: How To: Stop "Rust Dust" on Brake Rotors After Washing Car
