How long should I wait?
matt- you got it backwards...
first off, carnauba theoretically needs minimal cure time (between coats)- i usually give it a coupla hours. two coats of wax is the most you need... not the case with synthetics- infinity is the most on those!
and the backwards part is - put the wax over the synthetic. synthetic binds to the clear coat- and will not bind well to wax.
