How do you clean the "ENGINE START" button?
After almost 4 years, I noticed that my "ENGINE START" button is collecting dirt in the recessed lettering. So what is the best way to clean the dirt out of the recessed lines of the letters? Wiping does not help, as the dirt is below the level of the surface. Thanks.
Dab a "Q-tip" in some simple green and work at it. Shouldn't be a problem since the contours of the Q-tip will be able to swish out any dirt in the grooves of the letters.
Good luck
Asif
Good luck
Asif
exactly my post from about a month ago!!
simple green applied to a towel then to the start button... also the emergency blinker button,
should do the trick.
more ideas are in my thread, if you want to search for it.
good luck!!
good luck!!
start button cleaning
You asked the exact same question I did. I will try some of the suggestions made. Thanks again.
ryanswhites2k
06-08-2009 06:56 AM
