Help a noob please!
Help a noob please!
Hi! I'm a noob when it comes to car waxing. I have a few question for some of you pros out there.
I'm currently using Klasse AIO, SG, and P21s.
The step I take is ... :
Wash, then Claybar, then Meguire DACP (Swirl Remover), then Klasse AIO, then 2 layers of SG, and then last... P21s.
Is this the right order? Any suggestions?
My question is, should I be applying P21s with hand or Porter Cables?? and is it layer able???
Also, is there a better choice than Meguire DACP for Swirl Removers?? DACP really isn't working for me... the swirl is still there........
Sorry, for the many questions.. hope is not too much trouble... thanks
Sounds like you will have great results with that order.
P21 can be layered. I usually spread/remove carnauba by hand, but it can be spread by PC.
Menzerma Intensive Polish and Final Polish work well for my swirls (orange pc pad if they're tough). They also have a product called Power Gloss which is a step more aggressive than IP.
I've used IP+FP+AIO+SG on a really beat, heavily swirled, black finish with outstanding results. The P21 will add that much more depth and warmth.
Good luck.
Good luck.
