Headlights peelings?
Old 06-20-2006, 03:39 PM
  #21
SheDrivesIt's Avatar
Um, since you are Zainoing your headlights, could it be a film of Zaino that is flaking off?
Old 06-20-2006, 03:46 PM
  #22
pikkashoe's Avatar
No, its the actual material like peeing or blistering, its tough to explain, but usace's pic show the exact thing thats happening to mine.
Old 06-25-2006, 10:27 AM
  #23
xviper's Avatar
Today, I have seen this phenomenon first hand on a friend's S2000 (MY02). Plexus will momentarily hide this hazing effect, but as soon as the Plexus dries, the hazing comes back, only not as dramatically. This confirms to me that the imperfection is within the plastic of the headlight lens just under the surface. It is my belief that this has been caused by UV radiation over an extended period of time and it is magnified by virtue of the background being black. This would cause the lens material to get exceptionally hot and aggravate or promote this "deterioration". It is definately NOT from pitting due to normal daily driving and having foreign materials hit the lens. I doubt that polishing the surface will do anything as the imperfection is within the under-surface layers of plastic.
I have a thick layer of 3M film over my headlights since the first week I've had the car and it is perfectly clear. I think the 3M film acts as a barrier to prevent much of the UV radiation from penetrating into the initial layer of the headlight lens. Not all S2000 lenses do this. I consider that this is a manufacturuing defect that Honda should own up to. Whether or not they see it this way is yet to be discovered.
Old 06-25-2006, 02:34 PM
  #24
thetz99's Avatar
Polishing does remove haze
Old 06-25-2006, 02:49 PM
  #25
xviper's Avatar
Good to know. I've referred this thread to my friend so he can give the polishing a try. Hopefully, the haze isn't too far into the plastic.
Old 06-25-2006, 02:51 PM
  #26
xviper's Avatar
Originally Posted by pikkashoe,Jun 15 2006, 06:48 PM
and the more u polish the more it spreads
This is what I would be most worried about.
Old 06-25-2006, 06:39 PM
  #27
FormerH22a4's Avatar
I don't think polishing will save mine, tried polishing with Zaino, with another wax and now Plexus, still a bit foggy. I think it is beyond help so i'll just try not let it get any worse.
Old 06-25-2006, 08:38 PM
  #28
thetz99's Avatar
Everything you mentioned is NOT a polish but sealants or protectants. You need to be using something that has abrasive properties like a swirl remover (zaino has swirl covers).
Here is my headlight polishing thread
https://www.s2ki.com/forums/index.php?showtopic=296109
HankookS2K
09-26-2013 09:37 AM
fcukash
07-09-2007 10:12 PM
dthondatune
12-06-2006 04:55 PM
Jay Li
07-12-2002 12:04 PM
loki
08-06-2001 10:28 AM
Quick Reply: Headlights peelings?
