Got my UDM! Cement mixer noises normal?
Hey there everyone, I finally got my shipment from autogeek. I read the users manual and finally plugged the UDM in. I put the white pad on it just to see how it felt like. It works fine at all speeds and spins like crazy at speed 6! I just have one question, is it supposed to sound like a cement mixer/vortech'd skl at startup?? The sound is present at all speeds but becomes less audible as speeds increase. Any help/opinions would be appreciated! thanks you guys
Part 1-with white pad
YouTube - UDM
Part 2-no pad
http://www.youtube.com/watch?v=Snyi87Yugr8
excuse the packaging mess in the background that clicking noise you hear in the end is me adjusting the speed
YouTube - UDM
Part 2-no pad
1. you win the creativity award... perfect to post it up as a youtube!!
2. unfortunately, the sound did not tell me that there is a problem- didnt sound great, but an not sure with the sound quality that i got...
what area are you in? maybe we can find someone in your area who could "listen live"- if not, you could post the question up in your local forum
it is possible that someone else will be able to get better sound than i did and will be able to diagnose this... i am not trying to taint your answer!
thanks wanabe, Ill try and take another vid with the UDM further away from the camera, it seems like im getting wind turbulence. Im located in San Diego,CA if that matters. thanks
Edit
I added another vid, see part 2 in the original post
I also searched this video, its a PC7424 and it sounds pretty similar??
http://www.youtube.com/watch?v=89323lmQ2LI
some people say that the noise goes away once there is a load placed on it. Supposedly it has to do with the bearings and rotation and no load.
Edit
I have a brand new Porter Cable and it makes the same noise with a dry pad on it, not polishing anything. Detail to come this Saturday so I'll see if it does the same thing.
I just received my brand new PC and it seems to make the same noise... whether under load or not.
It sounds as though there is something loose inside the polisher, like a bearing.
I was surprised. Is this normal? Sorry for the vague description, but I've used other orbital polishers (not random) and they are a smooth spinning sound... this one sounds very rough
Sorry I meant other Rotary's not Orbitals
And yes I have the handle screwed in... I've googled the PC 7424 and others have found it to make this metal 'tank' sound as well... I guess it's normal
Originally Posted by Ubetit,Jan 15 2008, 10:45 AM
The bearings have no load on them. I don't even thing the machine is supposed to be operated that way.
However when I first fired it up to polish, it was making the tank sound so I pulled it off the car right away, still made the sound but only more noticeable without load on it
I will consider it normal and crank the tunes up
