Going to attempt "scuff" treatment after tape removal.
I have just removed the windscreen tape and I have one scuff mark on the passenger side upper corner, about the size of a thumb print.
I decided to pick up some Meguiars ScratchX, but before I attempt to use it, I thought it would be wise to ask for other opinons first
Any thoughts?
Any thoughts?
scratch x is a good solution and is not too strong- if concerned use it on a small edge first and then expand the area.
you should not need to swirl remove after scratch x.
(if you have a swirl remover already, you could try that first).
but you will need to rewax after..
let us know your results-
btw, we have assumed that the scratches are not down into the primer or beyond-
[btw, we have assumed that the scratches are not down into the primer or beyond-
All done. Managed to get it 98% clear, but if I catch an angle and look hard, I can just see a minor remnant of swirls.
I will see how it looks in natural light, but I am initially very pleased. Thanks for all of the advice.
feels good to help-
sounds like you could finish it off with either the scratch x or a swirl remover-
if it was me, based on your report that its pretty much cleared up, i would live with it until the next time you detail the car then go after it once more-
petercs17
03-23-2006 10:16 AM
