gilmore faommaster II?
Just got one of this from chemicalguys.com.
Anybody using this right now? How much shampoo do you put into the bottle and how much water do you add to it???
first time when I used it. I pour a little bit into the bottle then add water to top. but it seem like going out pretty quick..
any idea??
any idea??
My FoamMaster caused me to switch from Lusso Oro bathe to Mequiars gold wash. Unless you turn the dial to "A" where it mixes the least amount of solution, it's going to go pretty quick. Even at A a full container barely gets the car done.
I have mine set on "C". I do not dilute the soap. I am using Chemical Guys Citrus Clear and have a soft water tap in my garage. It comes out like snow and I do not use much soap to cover the entire car. When I get my CR Spotless, it should use even less soap.
I use C setting with CG Citrus+Gloss wash and Maxi Suds II. Fill the container about 25% with soap and it lasts for a few car washes.
If you use Mequiers Gold Class, you will need to dilute it to get the gun to pick it up. It is just to thick out of the bottle 25% soap and the rest water. Goes real fast though.
DaveFromSydney
79
11-28-2004 01:03 PM
Cigar Man
10-05-2002 05:53 PM
