getting ready 2 polish my car and wax it
well i check the paint 2 make sure i don't need 2 clay it and its fine no bumps aww smooth like glass aww now my question is when i polish i use small circles (this is by hand) and do i do the same with the wax i am using 3m perfect-it foam polsihin pad glaze swirl mark remover for dark colered cars and i am using 3m perfect-it show car paste was ultra high gloss finish
i use straight lines.
my very strong preference is to use a porter cable for any polishing- you will find out why very soon if you attempt this by hand!!
i do a "box" about 2 x 2 feet.
up and back up and back until the box is done- then side to side side to side until the box is done. some folks then do diagonals too.
then repeat and keep repeating until the polish hazes. then remove the small hazed amounts and you should have perfection. move on to the next box and keep that up until the car is done.
then wax - as the air flows over the car is how i do it (front to back)
does that help?
yes it does.... aww well i work at lowes and there porter is the the same model as the one everbody talks about i think the model 73434 or something like that or close i just know it has a 3 in it. thanks
