Foam Guns...
Old 09-27-2007, 11:41 AM
  #21
steadyc's Avatar
I use a cheap hose sprayer that has a canister @ the bottom. I think they are for spraying lawns. Got it at home depot. It's like the cheap ones @ walmart, but has a bigger canister to hold more soap/product. Makes good foam. I use a premix gallon of poorboys super slick to fill the container and set the rate at the highest setting.
Old 09-27-2007, 12:03 PM
  #22
lordbyron's Avatar
aww sould have said some thing earlier.. ordered my foamaster last night
Old 09-27-2007, 03:27 PM
  #23
steadyc's Avatar
Sorry man....
Old 09-28-2007, 01:20 PM
  #24
dmw16's Avatar
In the home depot sprayer, what ratio of something like meg's gold to water would you suggest? or do you just fill the sprayer with all soap?
Old 09-28-2007, 04:05 PM
  #25
steadyc's Avatar
I use an Ortho Dial and Spray Multi-use Hose-end Sprayer.(home depot)
cup capacity is 32 ounces. I also use a hose quick connect purchased @ wal-mart
I've been using poorboys super slick soap. !/4 cup in a gallon bottle. I set the sprayer setting to it's max 8 oz. Make sure you shake up the gallon bottle really well before using. Makes good suds imo. I just use it as a pre-soak. My method is under the wacko influence brought on by this fine forum is:
rinse really well
use foam gun let sit for a bit
rinse again
2 bucket method using grit guard in each bucket
I've been using sheep skin mitt, but recently purchased an all white ShMitt.
I also use warm soft water. I plumbed a hot water line to my front yard
Also I find poorboy's a bit pricey so I'm gonna try gold class next time around..It's just a pre-soak so I'll save the poorboy's for the bucket.
there are a lot of steps I left out, but I don't want to expose my extreme OCD
Old 09-28-2007, 04:08 PM
  #26
wanabe's Avatar
your secrets are safe with us!!!
Old 09-28-2007, 05:57 PM
  #27
steadyc's Avatar
This forum is great. I have no secrets. What I do have is many "thanks" for all the great advice in this forum.
Old 09-28-2007, 07:46 PM
  #28
FMINUS's Avatar
Foam Cannon
Old 09-28-2007, 07:50 PM
  #29
RFGrouse's Avatar
Yep that is how mine works. It makes life some much easier. Add a bit of p21s auto wash for the cars to be polished and it works wonders.
Old 09-29-2007, 10:08 AM
  #30
steadyc's Avatar
That looks really cool F-minus..That's a pressure washer attachment correct? I wonder if my cheap one cand do the same with just a straight (or stronger) solution? I may have to give it a try. I'm gonna try that jet steal you also recommended. It's a sealant right?
Quick Reply: Foam Guns...
