Film on windows - HELP! Can't see when it rains!
Old 01-19-2005, 11:35 AM
  #31
Fusiondynamics's Avatar
Go to any auto parts store and look for "glass scrub." There are different brands out and most should work the same. I know what your talking about. It's like an invisible film that is only there when it rains and the wipers don't wipe well. I had the same thing and the glass scrub worked. It shouldn't cost you more than 5-6 bucks.
Old 01-20-2005, 03:19 PM
  #32
JSR_AP2's Avatar
Sam: check u'r PM.
Fusion: thanks, I'll check out my local Pep Boys and Kragen.
Old 01-21-2005, 09:33 AM
  #33
flitcroft's Avatar
I agree with Mike above. You really just need to polish your glass. I did it with 3M Swirl Mark remover last week and it worked wonders.
The steps:
1) Apply some fine-cut polish
2) Polish well with microfiber
3) Buff with clean microfiber
4) Wash windows x2 -- I use Stoner Invisible Glass and newspaper for this
5) Optionally: Buff in two coats of Rain-X (you can apply the second coat onto the first wet coat -- it's just for coverage) to make sure you're windows are great for another 6 months.
Old 01-21-2005, 09:35 AM
  #34
flitcroft's Avatar
If that doesn't work you have to use a machine. This article explains that process. It will fix just about any piece of glass that is not cracked.
http://www.properautocare.com/polishglass.html
Old 01-27-2005, 03:59 PM
  #35
MyBad's Avatar
I've had a similar problem and have wondered if the wiper blades contribute to the problem. At times they drag and deposit God-awful rubber gunk on the glass. I have to scrape it off.
Old 01-27-2005, 05:30 PM
  #36
flitcroft's Avatar
^ Yep, mine just did that for the first time the other week. There is commercial rubber renewer available but I usually just use rubbing alcohol and clean them a few times with paper towels. That solves the problem for me.
Old 02-04-2005, 08:02 AM
  #37
Dolemike's Avatar
Its oil from driving on the road... other cars sling it up, dont notice it until it rains or when the sun hits the windshield at the right angle the glass looks sparkly like glitter or some $hit is on it... or splotchy looking like water spots? The lower the car is the more common this is... RainX has always done the job for me in taking care of this issue. Be liberal with the first coat of RainX wipe off and do one more coat on it, wipe it off... and POOF! its gone. Hope this helps
Old 02-04-2005, 09:50 AM
  #38
NNY S2k's Avatar
Did you ever get it off? If so, what worked?
Old 02-04-2005, 03:33 PM
  #39
MyBad's Avatar
Mine was so bad (How bad was it?) that I had to use wax on the glass to clean it.
btw, wax on the plastic window does magic too. Just don't get it on the black vinyl!
Jaeden09
08-27-2007 09:24 PM
naruto
08-01-2005 03:51 PM
s2ka
07-02-2003 06:52 PM
J.T
01-15-2003 06:12 PM
wirejock
03-12-2001 05:14 AM
Quick Reply: Film on windows - HELP! Can't see when it rains!
