Exhaust Polishing
Exhaust Polishing
Anyone know what I should use to polish a stainless steel exhaust system? Do you recommend cleaning the inside of the system? How would you go around to do that?
How about polishing the titanium tips?
Heard a couple different things.. I have used Nevr Dull or something like that. Works pretty good, there was one a couple post back about someone using some kinda polish cream.. I'll try and look it up.
Edit: https://www.s2ki.com/forums/index.php?showtopic=565928
there you go. Do a little research first, then ask. It was the second page of this forum.
just to add to this thread :
be very careful with the ti tips. its a real pia to reblue tips if you accidentally unblue them.
as long as you go easy you should be fine. i always test underneath to determine whether the product will work and just how much pressure i can use.
Originally Posted by detailersdomain,Feb 17 2008, 11:00 PM
I was going to say the blue tips maybe an issue.
Lesson learned. At least it was a cheap, knock off shift knob, and not some pricey JDM piece.
A related question- After you polish your exhaust system, is there any product that can be applied that will withstand the heat and protect?
One more- Has anyone tried the stainless steel polishs that are sold to polish SS appliances like refrigerators and stoves?
