Edge Pads Ruined?
Old 08-24-2007 | 06:29 AM
02SuzS2k's Avatar
Default Edge Pads Ruined?
Quick Question. My brother uses my edge pads and didn't clay before he waxed. His truck = gray, my car = black. Seeing as how black gets swirled so easily, do you think the pads probably picked up debris and would swirl my black paint? If so, you think they could be salvaged or should I say keep em and buy new ones????
Old 08-24-2007 | 07:27 AM
MikeyC's Avatar
I'm sure they're fine. I always clean my pads after use anyway because eventually they would be filled up with dried polish which would not be good either.
You can soak them in a bucket with with a solution containing some car wash soap or better yet carpet cleaner. Some people use Dawn but some pad manufacturers say Dawn is bad for the glue which holds the pad together.
Old 08-24-2007 | 08:20 AM
Jaeden09's Avatar
I was wondering what to soak my pads in, cause they are getting CAKED with stuff. I've used Pinnacle's Pad cleaner, but it only does so much. My mom started using my UDM when I got it, and she was apply Zymol Cleaner wax, and just CAKING it on the pad, not knowing she doesn't need that much, and it's traumatized my pad.
Old 08-24-2007 | 08:39 AM
wanabe's Avatar
try a pad spur... best to use after polishing, but should help even now-
might want to wet the pad first (maybe soak in water)
best to use the spur to get as much loose as possible, rinse off, spur again until most is off then use the pad cleaner
Old 08-24-2007 | 08:44 AM
wanabe's Avatar
clay and wax are separate and not required steps...
claying will not effect your polishing one way or the other
clay removes embedded particles
polishing removes surface defects
in the old days (and not all that long ago), we didnt have clay... polish was used for both.
conclusion- no problem with your process
(pads should always be cleaned after use- so as long as they were you are fine)
Old 08-24-2007 | 08:48 AM
Jaeden09's Avatar
Well, my pads are stained, that's my problem. I got most of the surface stuff off by washing with really hot water, and soaking, but I didn't know of a way to remove the stains.
Old 08-24-2007 | 08:55 AM
wanabe's Avatar
most of my pads have stains...
no big deal, and prob more normal than not
i just try to get all excess product out, and not as worried about how the pads look- as long as the product is out it cant harden (that is the potential danger)
btw, i "dedicate" my pads- by car (used to also do this by product, but too many diff ones now so have not been able to do that for awhile now) - thats the most wacko you can get... but as long as you are not a pro and only doing a few cars its not hard to do.
(and actually my beater cars do share pads)
Old 08-24-2007 | 09:06 AM
02SuzS2k's Avatar
Good point, didn't think about that one.
Thanks for the input.
Old 08-24-2007 | 09:22 AM
wanabe's Avatar
it was a good question, and i am glad you asked it cause not everyone is as vintage as me!!!
Old 08-31-2007 | 10:15 PM
FMINUS's Avatar
Dawn Power Dissolver works great for me, spray pad, let sit for 10 min, then rinse under HOT water. Works better than any pad cleaner I have used.
j2damilla
04-12-2011 09:00 PM
Porsche951
04-07-2008 02:41 AM
boyguan
03-22-2008 12:28 AM
Driv300mph
06-29-2005 08:50 PM
amartin
09-03-2001 05:58 PM
