Convertible top fading ?
Hey, I was just wondering what you guys do to protect your convertible tops from fading ? Mine is black and looks good so far but is there like a protective coat or spray you can add to help the life of it ? Or pretty much when it fades you just replace the fabric ?
Thanks alot =]
Thanks alot =]
alot of people seem to use this, i do as well. its good to keep it look like new.
http://www.canadiantire.ca/browse/product_...408474396672470
raggtop or 303 VINYL cleaner protectant, best applied with a firm foam/microfiber pad. detailersdomain.com should have what you need. you could also try properautocare.com
if you use DD.com, put s2ki in the coupon box at checkout for 10% off
DD raggtop kit
DD microfiber pads
Other products here on another site, plus links to items to care for the rubber seals on the top as well.
Here's a how to thread on how to apply the products and care for the top
hope all this helps out, and like the others said, be sure to check out the wash and wax section for lots of great info!
james
DD raggtop kit
DD microfiber pads
james
Originally Posted by rj2000,Jun 16 2008, 07:59 AM
What can you do about the plastic window ? Any care products for that ?
and our "how to" for the top- you already have good info above, and this will make it even more complete:
https://www.s2ki.com/forums/index.php?showtopic=585993
