Cleaning Windows
Cleaning Windows
I picked up some good tips from Detailed Image, a website, I picked up on this forum. The tips for cleaning the haze which forms on the interior windows especially the windshield as a result of the outgassing of the plasticizers in the vinyl is to use Isopropyl Alcohol before using any preferred cleaner. The recommendation is full strength but I used a 50/50 solution and it was amazing. In just one application on the windshield it removed almost all of the haze. I followed up with Invisible Glass and it has been haze free for several days. I did cover the dash to make sure nothing got on it. The second tip was to use a window cleaning MF towel for the initial wipe and then a clean MF towel for the final wipe before the producct dries so as not to wipe the surface again with the dirty side of the first towel which spreads the stuff you just removed. Or, use the flip side of the dirty towel followed up with the clean towel. You use a few towels but it works great and so far it stays clean.
Another excellent cleaner (and low cost) for that haze is to mix a spray bottle with tap water and one ounce of vinegar. Rather than use a MF towel, try a sheet of newspaper. It works just as well and leaves no lint.
Originally Posted by RiceMan,Nov 15 2010, 10:45 PM
Newspapers do the magic for all kind glasses, cheap and super clean!
old school seems to win in this case
Hobb
10-11-2002 12:10 PM
