cleaning window dirt once rolled
well i washed my car and its all clean but as soon as the window comes down even after and hour there will be water markes on windows again. is it just dirt in between the door and window?
yup-
when you are drying the car, roll down the windows and push a rag down a bit inside where the windows touch the sides- should be able to get it by rubbing front to back on both sides.
roll windows up and dry them off. sometimes i also roll them down again, and back up and dry again. a few times of that and they will be dry. the main key is to dry the track when the window is down.
Originally Posted by thorax,Apr 29 2007, 03:26 PM
so stick the rag between window and the black piece?
roll the window down all the way and then do it-
easier to get to the moisture that way
