Cleaning the underside of the soft top?
Old 07-27-2011, 10:04 AM
gforgary's Avatar
Default Cleaning the underside of the soft top?
I'm convinced the underside of the soft top is making my car smell. I've vacuumed it, but what is a safe surfactant to use to clean it? It seems pretty dirty. Thanks!
Old 07-27-2011, 05:02 PM
S2KRAY's Avatar
Is there a mildew odor that you smell. Mildew cleaner may work and should clean the underside of the top. Never had this problem with 2 S2K's so I am not sure what to recommend.
Old 07-27-2011, 11:31 PM
BlackBearTX's Avatar
Hmm maybe some convertible/vinyl cleaner, spray directly onto a microfiber cloth and work it on the underside?
Old 07-28-2011, 04:21 AM
dirtykoala's Avatar
i use 303 on the inside of mine in the front for UV protection when the top is down.
Old 07-28-2011, 05:53 AM
JEEBS's Avatar
I used Raggtop Protectant and it seems to do the trick. Maybe use 303 or Raggtop to clean it first and then protect it. I had my top down for 30 mins the other day and the small portion that is exposed got dirty/sun damage.
What kind of smell are you talking about? Maybe check your rain rails to make sure there is nothing caught in it. I just changed out my soft top w/ frame and found some Oakleys and a hair pick. It was in the rain rail.
Old 07-28-2011, 01:57 PM
gforgary's Avatar
Thanks for the tips, I will clean my top anyway, but I did smell a little closer and I think it might actually be my seats. I cleaned it again, so hopefully it'll be better tomorrow. Maybe I should leave it out in the sun for an hour and see if it kills any germs or whatnot.
Old 07-29-2011, 02:03 AM
smohan123's Avatar
Oakleys and a hair pick?!
Old 07-29-2011, 06:49 AM
JEEBS's Avatar
No lie! I have two other member that helped me with the install that can vouch for that haha.
I guess what happened is, somethin was left on the softtop and when it was folded back, those items ended up in the rain rail.
Old 07-29-2011, 08:35 AM
gforgary's Avatar
Got my Oakleys, no hair pick =P
Ok I think it's my seats - is it possible to clean UNDER the leather of the seats? It doesn't kill me, but it is not pleasant. It goes away after a while but I rather not be greeted with it every time I drive the car.
Old 07-29-2011, 10:50 PM
dirtykoala's Avatar
take the leather off of the seat?
Quick Reply: Cleaning the underside of the soft top?
