Cleaning plastic window
Start with Plast-X from meguiars, maybe using it with a small electric buffer. I got a kit that provided you with a buffing tool that you use with a drill, and came with Plast-x polish and sealant.
Wetsanding sounds a bit too harsh for the condition it is in (relatively decent), I would leave that as a last resort if the milder approach doesn't work. Once you get it cleaned up keep it protected with a sealant like Menzerna Powerlock, and regular use of Plexus.
I cleaned up my Mugen Lexan window with this method and since then it remains perfect with the sealant and Plexus maintenance.
Clean with plexus and add a piece of carpet onto the plastic tray where it touches when you fold your top down.The carpet will prevent the dust from sticking to the hot plastic.
