Cleaning Burnt Titanium Tips?
Hey guys, what's the best way to clean burnt titanium tips? I know regular metal polish will strip the titanium look... any tips would be helpful!
This is my exhaust:
This is my exhaust:
most non-acid wheel cleaners will work...
just test on the underside to make sure that they do not deblue the pipes before you use them.
i always start out with just a car shampoo- then if that doesnt get it then i go more aggressive, like wheel cleaners.
you are right that you can deblue with metal polishes, so be careful there. kinda pia to reblue. i have never done it, but i understand the process is with a blow torch and usually with the exhaust off of the car.
btw, wd-40 is also worth trying... again, try it underside first
i would use the car shampoo first, dry them then some wd-40, as another choice
