clay bar over Z2?
clay bar over Z2?
I applied Z1 and Z2 a few weeks ago but do not like the fact the surface is super smooth. Can I use clay bar over the Z2? Also, will using a meguiar's clay bar with detailer mist as the lubricant adversly react with the Z2? Do I have to use Zaino's clay bar?
Yes, you can clay over the Z2. It will pull the contaminents through the Zaino, but I would suggest following with Z1 sooner than you had planned.
I don't think Meguiars is a good clay bar, but you can use any clay you want. I like Zaino's and Mother's clay bar. I would also suggest using the capful of Z7 and water instead of their detail spray as the lubricant. An easier way would be to do it while washing, one panel at a time. Of course, wash it, then rinse it, then wash it again while claying. Then one more quick go over after you're done claying. This is to make sure you always have plenty of lube.
