Cam Spray Foamer
#21
very very nice! lots of foam!
one question mikey, i have a pressure washer as well but its gas powered. so its 3000psi. Is it still gonna produce as much foam or should i just get an electric one?
#22
Now I'll ask some really dumb questions. Where do you get this Cam Foam Cannon? How does it attach to the pressure washer? I like the looks of the results, and my pressure washer is also located conveniently so I use it for every wash.
Now, for the guy who wanted to be able to wash his car without touching it, it can ALMOST be done, and I'm sure the Foam Cannon would help. To do this, the car has to be waxed really well. You can do the washing with a boar's hair brush on a pole, and dry it with a leaf blower. Not perfect, but not bad either.
#23
#25
Originally Posted by Carbon Blue,Oct 16 2007, 07:12 PM
I did see that vid of the guy with the superbee, it seriously did look like he was spraying shaving cream onto his car!
#26
Originally Posted by MikeyC,Oct 15 2007, 08:24 PM
There was plenty of soap on the paint. So, I just went over the paint with my ShMitt. I first dipped the ShMitt in a bucket of water to wet it and returned it to the bucket as needed to remove any dirt on the surface of the ShMitt.
There is no such thing as a truly touchless wash that removes all the dirt. In order to remove 100% of the dirt on the paint it needs to be agitated in some fashion.
#27
Originally Posted by racecarpete,Oct 16 2007, 08:18 PM
So to Clarify, you are no longer using a 2 bucket method. You are using just one to rinse out the schmitt. Is this correct?
Honestly, I haven't been using the two bucket method in some time. The ShMitt releases dirt SO well that I just use a wash bucket. I don't even use a Grit Guard anymore. There are no hairs or knap on the ShMitt to grab and hold onto dirt. So there's no point in using one. If I do get some stubborn dirt on my ShMitt that won't release I just scrape it against the edge of the bucket or rub it out with my other hand.
#28
Great! That sounds like it would speed things up quite a bit for me.
I really didn't see the point if the two bucket method was still needed.
Everytime MikeyC does a review my wallet cries a little more...
ladius
12-02-2011 08:19 PM
Mr. Eryozgatliyan
12-20-2007 01:06 PM
ebeldesign
40
10-27-2007 03:34 PM
