broke plastic window
my dumb brother just broke my(second new) plastic window when he was playing with the soft top......he felt my fu... fury .....anyway i want to install the glass one, but i heard that it needs some modification on the frame .....help with the link on how to do so...please
sorry if this doesn't belong here
You couldn't put the OE glass window (02-03) into the (00-01) because it folds differently. You would need to replace the full frame as well as the top and the glass is slightly bigger and not interchangeable
contact Hardtopguy for a more detailed answer
http://www.hardtopguy.com/store/customer/home.php
Look at the size of the opening,in a top with a plastic window,and compare it to the size of a glass window.
Glass window is much smaller.
You cannot fill a big hole,with a a small glass window.
Well, if you just get a plastic window and treat it with 303 once in a while. it wont break, because it will remain too soft and supple to break. This is your cheap fix. But with this treatment, my 4 1/2 year '01 plastic rear indow is still as soft, supple and clear as the day it was new.
Thanks,
Richard
Thanks,
Richard
BlackNightmare
i found the pictures. but i just bought the whole 04 frame and motors and glass window with top for 350 so i think its just bolt on now.
could you tell me where did you get it
