Body shop or detailer to fix long, fine scratches on hood
got a number of short and long fine scratches on the hood and the trunk after ice sliding off of the car after the long winter. scratches are very fine, is it better to bring it to a detailer or to a body shop?
Detailer should be able to remove the scratches based on your description. I would go see one and have him take a look. He (or she) will be able to tell you if they can be removed with polishing.
Does your fingernail catch in the scratches? If not, then most likely they can be polished out. Either way, I imagine that it would be better to go to the detailer first. If they can fix it, should be able to do it for less than a body shop would charge.
I would actually go to a body shop and talk to their detailer. Fresh paint needs to be wet sanded to remove any imperfections like runs, dirt, too much peel etc. Also an older car that gets a front end painted should have the other panels that were not painted cut and polished to make the vehicle more uniform. They have a lot more seat time with a buffer than someone at a dealership as an example. Someone who is good with fresh paint is really good with cured paint. Besides, they mostly work with paint rather than leather seats and carpets like non body shop detailers do. Look for a veteran, not a 17 yr. old with a buffer. My 2 cents.
I agree MikeyC and metros. I would not take my car to a body shop to get my car polished. As suggested, visit the detailing forums like Autopia and see if you can find a professional detailer in your area. If you can't find anyone locally, then consider investing in a dual action polisher, pads, and polishes and doing the work yourself.
