Best Way to Remove Tar from Body Panels...
Old 07-26-2010, 09:58 AM
zeroptzero's Avatar
Received 3,772 Likes on 2,661 Posts
Default Best Way to Remove Tar from Body Panels...
I recently got some tar sprayed along the side quarter panels behind the front wheels. There has been some road construction in my area recently and it likely picked up from the new road asphalt. It is mostly thin long lines of it sprayed out behind the front wheel wells. I want to detail my car soon with a good polish and wax , I'll need to remove the tar first. Any advice on products to use to remove the tar ? . I'd appreciate any recommendation, thanks for reading.
Old 07-26-2010, 11:59 AM
00CivicSi's Avatar
I've always had good luck with Meg's Bug and Tar remover.
Old 07-26-2010, 01:29 PM
slanguage's Avatar
I used Lifter 1 bug and tar remover on some nasty tree sap recently.
It worked better than I expected.
Picked it up at PepBoys.
Old 07-26-2010, 04:33 PM
S2KRAY's Avatar
Tarminator with a rigid porous sponge that I got from my detail supplier's website. Easy to use and very effective.
Old 07-26-2010, 04:47 PM
zeroptzero's Avatar
thanks for the replies on this, some of those products should be easy to find over the counter for me. That's great, thanks again.
Old 07-26-2010, 06:29 PM
AndrewC's Avatar
I keep one really nasty clay bar for these kinds of jobs and the clay pulls it off no problem. Just max sure you waxed the area before you go to clay as you don't want to scratch anything around/underneath the tar.
Old 07-27-2010, 07:31 AM
bcs
bcs's Avatar
I usually use some sort of bug/tar remover and then go over the area again with a clay bar. Then polish and wax as needed.
Old 07-28-2010, 02:50 PM
zeroptzero's Avatar
Im going to clay the car before I polish and wax so the claybar tip should work well, thanks for tip on this.
Old 07-28-2010, 11:03 PM
ThatSlowKid's Avatar
the recent i did was that Sl500 and had lots of bugs,tar and brake dust baked on it. I just applied meguairs bug and tar removal and washed it. Some of it was gone and then the rest i did with clay bar. worked out pretty good.
Old 07-29-2010, 07:08 AM
DC2AP1's Avatar
Diesel fuel clean tar pretty good but you need to wash and wax after.
Quick Reply: Best Way to Remove Tar from Body Panels...
