Applying S100
Applying S100
After I apply about 5 coats of zaino, should I just use an applicator pad and apply s100 just like zaino? or should I do sections at a time, because the instructions say don't let the s100 haze all the way. What are the steps you guys should suggest?
There are differing opinons:
I apply it to the whole vehicle first (in a shaded garage) and when I get to the starting point I just begin removing. I never had a problem with s100 removal. Although I never had a problem with this method, others have.
A number of people on Autopia boards apply it to small or medium size sections and then buff it right off. I don't know why they had issue with streaking but they did and the wipe on wipe off method works for them.
i apply one section at a time and move on to the next section while my assistant is removing the one that i just finished...
my recollection is that this is what the instructions with the product indicate.
a section is about half of the trunk, for example.
and as peraidm says, always out of the sun...
