Another Plexus success story...
I got my two bottles of Plexus and the magic towel in today.
My window was pretty dirty because of the rainy days that past. I also had a pretty long (3 inches) scratch on my window from putting my top down a week ago.
The combo made my window look like new and also, to my surprise, took away the scratch.
I am very pleased with Plexus.
I used to work on boats years ago and they all had plastic around the bridge. What a pain that was to keep clean. I tried so many things! Eventually I used Original Scented Pledge. Worked really good. Then it dissapeared out of stores!! So I tried everything under the sun. Nothing worked good. Then one guy told me to use this stuff called Plexus. It worked really good and ya know what SMELLED JUST LIKE PLEDGE!
So I was like hay I found it again! Knew it was "the stuff".
Use it all the time. You cant use it enough!
I ordered some Plexus from Autofanatics and it is on the way. It looks like it comes in a spray can. I assume that there is no problem with overspray onto the top or body of the car (wipes right off, leaves no mark, won't harm the Zaino polish, etc.)?
At first I only used Plexus and it worked fine. But after a few months I found that it was not enough. Off-gassing from the interior on hot sunny days caused spotting in the rear window. No amount of plexus will remove this kind of discoloration.
However, one application of Meguiar's plastic polish (#17) later and all the spots were gone. I highly recommend both Meguire's and Plexus. Plexus for everyday use and Meguiar's for the occasional scratch and off-gassing discoloration.
