Alternative to Shin-Etsu grease?
as i read it, these are the ingredients of shin etsu grease (someone please correct me if i have the wrong patent):
<<<" Adhesive grease composition comprising a random copolymer of ethylene and an alpha-olefin
An adhesive grease composition comprises a random copolymer of ethylene and an alpha-olefin having the following formula ##STR1## wherein R represents a lower alkyl group, x and y are, respectively, an integer provided that x/y=0.5 to 2.0 and x+y=50 to 150, and a thickening agent in defined amounts.">>>
source: http://www.freepatentsonline.com/4840739.html
Assignee: Shin-Etsu Chemical Co., Ltd. (JP)
Inventors: Mori, Shigeru; Takahashi, Takayuki;
and if anyone can make sense of it, pretty sure that this is their website:
http://www.shinetsu.co.jp/e/product/
Originally Posted by Incubus,Nov 28 2006, 02:41 PM
Be careful with cheap grease, I find Shin-Etsu is FAR superior. Other stuff will dry up.
I went to the Honda dealership and they recc. Pro Honda White Lithium Grease ""heavy duty general purpose lubricant".
It comes in a 12.5 oz. spray can and was something like $5-6 a can.
other data on label
*special solvents allow deep penetration
*sets up quickly to a thick coating
*use on metal hinges, pivots, and sliding mechanisms
*endorsed by Honda racing
UPC code #08732-0005
Having typed all of that I haven't used it yet. I don't see anything on label about use on weatherstripping but it is white lithium grease.
other data on label
Lithium is one of the greasiest, most anti-drying substances on the planet. White lithium grease lasts A LOOOOOOOOOOOOOOONG time, especially if it is not on a moving part. If you cant get shin etsu, WLith grease will work just fine. You can use black as well, but I dont recommend it on the top seals around the windows, because if you brush up against it with a nice freshly dry cleaned shirt, you will be all kinds of angry.
Originally Posted by NFRs2000NYC,Nov 28 2006, 01:28 AM
....try not to use silicone on rubber seals...once it is absorbed, the rubber cannot be treated again.
