3M Clear Bra
Thanks...here's what 3M said about care.
"Care Instructions
No special care is necessary for your kit once it is installed. You may wash and wax the product, just as you do the rest of your vehicle. You may experience a wax build up along the hood lines and other kit edges. Use a Q-tip or a soft brush to gently wipe away excess wax. Swirl or light scratches can be removed by gently wiping undiluted Isopropyl Alcohol onto the material and allowing it to evaporate. A layer of wax should be applied to the film as soon as possible after installation to close the pores in the clear coat. This will prevent bug acids and road grime from staining the kit. When using high-pressure sprayers, do not place the nozzle directly against the edge of the kit, or lifting may occur. Avoid picking at the edges or corners. Irreparable lifting of the material will result."
"Care Instructions
