'08 BB CR: Meguiar's DA Microfiber System
Old 12-20-2011, 06:21 AM
Driv300mph's Avatar
Thanks guys!
nlink720 -- I used Meguiars DA Microfiber pads, which are the only pads that can be used with the DA 2-step polish.
Thanks for the Menzerna recommendation DD & VanishingPoint -- I'll follow up here with another finishing wax pass in a couple months and top it off with Menzerna.
Old 12-20-2011, 09:20 AM
jaor.s2k's Avatar
that is why i want a black s, to make it look like a mirror lol
great job! and good looking cr
Old 04-13-2012, 10:00 AM
wanabe's Avatar
nice mirror on wheels!!
Old 04-15-2012, 02:40 PM
dwight's Avatar
Did you use the 5" or 6" pads?
Old 04-15-2012, 08:35 PM
sn0wman's Avatar
nice work! so basically you use this system after you wash and rinse and (clay if you need to)
Old 04-16-2012, 07:37 AM
Driv300mph's Avatar
Dwight -- I can't remember, I believe mine are the 6".
sno0wman -- yep, its a good system to use. I'm going to polish again within the next week with the first compound (d300). I won't be following up with the 2nd compound this time, but I will instead be using Chemical Guys' Black Light + V07 Sealant Detailer. Results should be even better
Old 04-16-2012, 10:54 AM
dwight's Avatar
It sounds like the D301 is an all-in-one so you might be missing out on some of the fine polishing that it provides.
D301 is a finishing wax designed just to remove any light hazing created by D300/DMC5 while adding a degree of gloss and protection.
-Michael Stoops
If you don't have any swirl, I don't see a need to go back to D300. At very least, I'd be cautious about using D300 without following it up with a finer polish for fear that it would leave a little hazing on BB which is generally considered to be a soft paint. Why not try using D301 for a fine polishing action and then washing the car with dish soap to strip the wax and then apply Black Light and V7?
Old 04-16-2012, 11:17 AM
Driv300mph's Avatar
Well, I do have a few swirls again. The D301 shouldn't be necessary this time around as the Black Light is also a fine polisher/protectant. Here's what I'm using in its place:
http://www.chemicalguys.com/Detailer..._p/hol_151.htm
Old 04-16-2012, 12:31 PM
dwight's Avatar
Yeah, I saw that before I wrote my post. I'm not convinced that Black Light is a polish. I don't see the words polish or abrasive anywhere. In addition they recommend their red pad, which is for sealants and waxes.
Old 04-18-2012, 08:11 AM
RedCelica's Avatar
-Michael Stoops
This. Phil (detailersdomain) recommended following up D300 w/ Menzerna SF 4000 and a green pad.
http://www.detailersdomain.com/Menze...art_p_684.html
Quick Reply: '08 BB CR: Meguiar's DA Microfiber System
