Front brake pads
Originally Posted by PanteraKitty,May 4 2009, 03:17 PM
Last time I looked, the inboard pads were wearing faster than the outboard pads - on all four wheels.
Thanks for the heads up.
Originally Posted by raymo19,May 4 2009, 03:50 PM
Crap! I hadn't considered that. Time for a closer look and most likely pad replacement all around. Fluid flush too.
The wear indicator is on the inside pad, so you shouldn't totally wear down the inside without any warning. (This is not true for track pads, which typically have no wear indicators.)
If you have a massively big difference between inside and outside, check the slide pins to make sure they are not binding.
Originally Posted by Jet sitter,May 4 2009, 01:11 PM
I just checked by front brake pads at 30K and found that they were worn below 1/2 of the pad. The rears are fine. I changed the front/rear pads on my 2000 Accord at 105K. Is this normal wear for the S?
You may want to look at different compounds - just be sure you keep within the operating temperature range (ie don't get race pads for the street - you'll never keep them up to operating temp).
