Front brake pads
Old 05-04-2009 | 11:11 AM
Jet sitter's Avatar
Default Front brake pads
I just checked by front brake pads at 30K and found that they were worn below 1/2 of the pad. The rears are fine. I changed the front/rear pads on my 2000 Accord at 105K. Is this normal wear for the S?
Old 05-04-2009 | 11:48 AM
mikegarrison's Avatar
It completely depends on how you drive.
I can (literally) burn through a set of OEM S2000 brake pads in about half an hour.
Old 05-04-2009 | 12:43 PM
raymo19's Avatar
All 4 wheels or just the fronts? I'm guessing there is some front brake bias. Mine are all still good at 45K but I haven't tracked the car.
Old 05-04-2009 | 12:47 PM
Newer S2000s may have a bias controller, I'm not sure. I think Honda calls it "Electronic Brake Distribution". Older cars, like the AP1s we seem to be talking about here, basically have a fixed bias and it's assumed the ABS will just kick in if necessary. You can tune the bias a bit on the older cars by running different brake compounds.
Old 05-04-2009 | 12:50 PM
raymo19's Avatar
I meant a fixed front bias. My car's older than yours.
Old 05-04-2009 | 12:59 PM
Jet sitter's Avatar
Thanks guys, appreciate the comments.
Old 05-04-2009 | 01:37 PM
dlq04's Avatar
short answer - sounds about right
Old 05-04-2009 | 02:21 PM
zzziippyyy's Avatar
Brake wear is mostly driver controlled.
Old 05-04-2009 | 02:35 PM
raymo19's Avatar
Or as my late father once remarked after I praised the brake wear on my '88 Grand AM:
"Son you have to use something to wear it out."
Old 05-04-2009 | 02:50 PM
zzziippyyy's Avatar
