Zero Compression
Zero Compression
So long story short, loose spark plug, i had to rethread the spark plug too, Tested compression on all four cylinders.. number four had low 185 and 3 and 2 had about 200 but one (which is the one with the bad spark plug tube) Had Zero, not even a little bit of compression.
hmm im confused, cause even if the cylinder was scored wouldn't it have some compression??
Originally Posted by Stealth_SUX_,Jun 19 2008, 03:34 PM
I was thinking that, just have to pull the head... ARGG
NotaMechanic431
06-08-2016 09:56 PM
Puppy
09-08-2008 12:50 PM
