zapping/crackling noise at 3000rpm ?
Old 09-21-2016, 05:49 AM
  #31
Reasonable Doubt's Avatar
Originally Posted by Caleb2k
have you recently changed brake calipers? i had a similar noise and it ended up being one of the brake caliper bolts came out. mine would hapeen when driving over a bump not a specific rpm, but check it still cause that can be bad if you dont
Nope, all stock. Never touched. Changed my rear brakes in January but that's about it.
Old 09-21-2016, 05:52 AM
  #32
Originally Posted by yessamgerg
I have AP front calipers and RX-8 rear calipers so I doubt that is the cause of this noise.
Ever since I made this thread the noise has become more annoying lol. It's really hard to ignore when you don't know the reason
Old 09-21-2016, 06:43 AM
  #33
windhund116's Avatar
Received 1,533 Likes on 1,037 Posts
Maybe best to try and get the car up on a hoist. Do thorough inspection.
Old 09-21-2016, 09:31 AM
  #34
Changed my front brakes and rotors over Labor Day weekend. Had my car on a lift. Banged and shook things around to see it anything was loose or broken. Everything seemed normal to me.
Picture on top of this page shows what Billman suggested to check and it was also fine.
The noise occurs at 3000 RPM even if I'm not driving which makes me believe it's not a loose part or a driving issue.
Old 09-21-2016, 11:11 AM
  #35
No loose sheet metal parts? Heat shields?
Old 09-21-2016, 11:44 AM
  #36
Planning to change my oil in about 100 miles so I'll put it on a lift again some time in October most likely. I guess I'll double check but I don't even know what to look for at this point.
All I know is that the noise occurs regardless of speed or gear. Parked on neutral, clutch in or out. Whenever I hit 3000 RPM it happens all the time
idsnow
10-10-2015 07:57 AM
Mr._ap1
02-07-2013 01:52 PM
ayS
05-12-2006 06:28 AM
Cardiff
01-16-2006 01:13 AM
Suave J
02-11-2001 12:08 PM
Quick Reply: zapping/crackling noise at 3000rpm ?
