Yellow Koni and H&R/Eibach springs??
Has enyone tested this combination??
I have heard that this would be much better than using a coiloverkit when you only want to lower your car 25-30 mm and upgrade your suspension.
I am planing on getting the Eibach ProKit springs and Koni Yellow struts for my S2000.
I had Eibach SportLines and Koni Struts on my last car, and I was very very happy with the results!
Shrubba
Shrubba
If you are planning to go Koni with Eibachs might as well spend the extra money and get the adjustable Ground Control sleeves which come with Eibach springs. That way you can adjust the height to suit your needs.
