Yellow jacket question
I just recently received a yellow box that was used from someone on s2ki. I verified that it worked on his car before switching his yellow box and gears into my car. I just wired my yllow jacket in, and the led light refuses to come on. The yellow wire is spliced into the yellow/blue wire, the blue and white wires are attached to their appropriate spot on the blue/white wire, and the black wire is grounded. I triple checked the wiring with the directions on modifry's website, and everything is perfect. I was told that the AP1 can be picky with where you cut the wires, so i tried a few different places, and the LED light still wont come on. I'm curious as to what could cause this?
I searched, and nothing to this affect came up.
Thanks.
Thanks.
Yes, i checked, it is ~5V, right where it's supposed to be.
I grounded it using the lower bolt for the hood latch like the install guide suggested.
My fault for the mistake, i'll correct it to yellow jacket.
I also heard that the yellowbox can do bad things if not installed correctly. Like short out the whole electrical system. Anywho, wish I could help but I had mine installed when I had my 4.77's put in.
