Yellow Box Settings?
Since there is not a single thread with yellow box settings, I thought we should have one.
If you don't know what a Yellow Box is, then you don't have one. But if you have changed your gears, or have change the size of your tires, you should have one. If you have questions about the Yellow box, you can search for the numerus thread on the topic, but this thread is just for settings.
For Example here is mine.
Model Year:2002
Trans MY:2004
Rear Gears:4.57
Rear Tire Size:285/30/18
Rear Rim Size:18x10
Switch Settings:01000001
Switch Setting %:16.25
How you calibrated:GPS
Please copy this code, and enter your settings after the "/b]"
Model Year:2002
Trans MY:2004
Rear Gears:4.57
Rear Rim Size:18x10
Code:
Model Year: Trans MY: Rear Gears: Rear Tire Size: Rear Rim Size: Switch Settings: Switch Setting %: How you calibrated:
Model Year: 2000
Trans MY: 2000
Rear Gears: 4.44
Rear Tire Size: 255/40/17
Rear Rim Size: 17X9
Switch Settings: 00101000
Switch Setting %: +10
How you calibrated: traffic radar
ps. Linking this to the FAQ's in Technical
Trans MY: 2000
Rear Gears: 4.44
Rear Rim Size: 17X9
Former Sponsor
Model Year: 2000
Trans MY: 2000
Rear Gears: 4.44
Rear Tire Size: 255/35-18
Rear Rim Size: 18x8.5
Switch Settings: 00101010
Switch Setting %: 10.5
How you calibrated: GPS
Trans MY: 2000
Rear Gears: 4.44
Model Year:2002
Trans MY:2002
Rear Gears:4.57
Rear Tire Size:245/40/17
Rear Rim Size:17
Switch Settings:0010 1000
Switch Setting %:10.00%
How you calibrated:3 different cars matching my speed.
NOTE: I left my speedo reading SLIGHTLY faster than I'm actually going. my factory speedo always seemed to be a bit quick by 2-3mph at freeway speeds (radar verified), so I decided to leave it as such. Otherwise I'd probably be about 10.5% or 11%
Trans MY:2002
Rear Gears:4.57
Rear Rim Size:17
Model Year:2002
Trans MY:2002
Rear Gears:4.57
Rear Tire Size:255/45/17
Rear Rim Size:17x9
Switch Settings:00100000
Switch Setting %:8%
How you calibrated:Mile markers
Trans MY:2002
Rear Gears:4.57
Rear Rim Size:17x9
Switch Setting %:8%
Can someone plz post the correct switch settings and % for the following:
Model Year: 2000
Trans MY: 2000
Rear Gears: 4.57
Rear Tire Size: 255/35/18
Rear Rim Size: 18x9
Switch Settings: ?
Switch Setting %: ?
TIA
Model Year: 2000
Trans MY: 2000
Rear Gears: 4.57
Rear Rim Size: 18x9
Switch Settings: ?
Switch Setting %: ?
TIA
Model Year: 2002
Trans MY: 2002
Rear Gears: 4.57
Rear Tire Size: stock, worn s02's
Rear Rim Size: stock
Switch Settings: 00111000
Switch Setting %: 14%
How you calibrated: mile markers (verified within 100 feet over 60 miles)
Trans MY: 2002
Rear Gears: 4.57
Model Year:2000
Trans MY:2000
Rear Gears:4.57
Rear Tire Size:Stock
Rear Rim Size:Stock
Switch Settings:00111001
Switch Setting %:14.25
How you calibrated:Mile Markers on Highway with almost new tires. 14.50% was a bit much, and i THINK that 14.25% was a little under, but BARELY. This was done with 10 mile runs.
Trans MY:2000
Rear Gears:4.57
Rear Rim Size:Stock
Model Year: 2002
Trans MY: 2002
Rear Gears: 4.57
Rear Tire Size: 245/45/16
Rear Rim Size: 16
Switch Settings: 0010 0111
Switch Setting %: 9.75%
How you calibrated: traffic speed radar
Trans MY: 2002
Rear Gears: 4.57
Rear Rim Size: 16
