YELLOW BOX problems!
I installed my yellow box last night everything seemed to be working correctly eventhough I did not get the chance to mess with the switches.
This morning while driving however I noticed several issues that weren't there before.
1. NO MPH
2. GAS gauge would move up and down similiar to the RPM Gauge
3. Odometer mileage wasn't moving
I pulled the car over at that point and unplugged the YB, reconnected the BLUE/WHITE wires and everything came back to normal...
Can someone look at my wiring and confirm that I got it right. If so, why is it acting up???
Not sure if this may make the difference, but I'm also running EMS and got the install instructions from here:
https://www.s2ki.com/forums/index.ph...&f=22&t=119078
4th BLUE/WHITE wire connected to GREY wire
4th BLUE/WHITE wire coming from the clip connected to the WHITE wire
RED YB wire tapped into the Yellow wire w/ Grey Dashes (NO Black Stripes)
BLACK YB Wire grounded
1. NO MPH
The Yellow box has built-in diags. In it on the instructions that shipped with it. But the short version is that either bad power connections (either one) of bad connections from the speedo wire will generate this issue. Pull the Yellow box out of the car, and install the small jumper connector that shipped with the YB. If you still have the issue, then it is surely your connections.
Originally Posted by s2kmaniac81,Jun 26 2006, 01:07 PM
figure out how to fix everything except the odometer and you will be sittin pretty!
Stratocaster:
"install the small jumper connector that shipped with the YB"
I still have the jumper connector, but have no clue on how to connect that part. I'm thinking its my power wire because that's the only wire that I didn't solder together, so will try that.
The green wire has been switched to Grey I think because I don't have a Green wire at all and others in the YB Install thread also have Grey wires now.
