X-Brace screw-up
X-Brace screw-up
I recently tried to install my X-brace and ran into a little trouble with the bolts. It appears that others on the board have had similar problems, and maybe they can HELP ME.
The bolt near the front left tire came out rough. While trying to put the new bolt in, I discombobulated the threads on the new bolt.
I thought, no problem, I'll just get a tap and repair the thread on the frame.
I tapped a crooked hole.
I decided to stop there and put the factory bolts back in.
The bolt that was giving me trouble would not go past 32 neuton/meters for about two turns. Just as I was thinking, I hope I don't strip the threads, it got ridiculously easy to turn.
Yeah, I did it. I just figured out that there are no threads on a frame or sub-frame of any sort. There is a nut that is welded to the car, this is the piece I damaged.
Before I drive the car, I will try to get a new nut to put on top of the stripped one, and I will get a longer bolt.
As of now, I will not go the Heli-Coil route because my way seems a bit easier.
If there are any suggestions, please let me know. I am afraid to drive the car now...
Thank You,
Barrett.
Thank You,
Barrett.
I'm afraid my post is like closing the barn door after the horse has run away.
I know what you just encountered except that I didn't continue to force the bolt. At the point where the last new bolt would not go in easily, I backed off, loosened all the other bolts PLUS I loosened the bolts holding the bracket that the X-brace bolted to. This bracket is bolted to the sub-frame.
This allowed me to thread the new X-brace bolts in without problem. At this point, all the bolts were snugged up, the bracket bolts torqued down, then the X-brace bolt torqued down.
As for fixing your problem, your plan will probably work. However, if you can reach it, try to "chisel" out the old nut first. If not, have you considered drilling out the old nut and tapping out a brand new, but bigger thread in that nut and getting a correspondingly bigger bolt?
I don't know what the hollowed out hole looks like-- but look into a "Helicoil" (possible spelling)-- basically, you over-tap the thread side, screw it it (reverse I believe), then u thread the normal size bolt through.. it works well on 2 stroke engines I'm messed up.
Good luck,
Aaron
Good luck,
Aaron
amartin,
I stated in my post that I will not go with Heli-Coil as of right now, but thanks anyway.
xviper,
See, I already have new bolts (Longer) and I plan to get a nut that will somewhat lock to the surface of the bracket and/or the bolt itself. I don't know about the integrity of the material, especially after something had been welded to it. Plus, I am now realizing that the bolt in the bracket right now might be hard to get out. I am most certainly not going to have an X-Brace on my car when finished.
I learned something last night: If you're the one that f'd it up, then don't try to fix it by yourself.
I have one of the smartest men alive helping me. He's my dad, and he's pissed.
Thanks for the help,
Suggestions still welcome...
xviper,
