WTF happened!
I read post everywhere with these swaps. It never hurt me in the past and I randomly started exp issues. I have two guesses, vtec solonoid is bad (if that even goes bad) OR a serious ground issue which prevents vtec from engaging and a/c from working fulltime.
Sounds like a grounding issue then. When I replaced the engine in my S it wouldnt start, but when I plugged a scanner into it, it started up perfectly. I realized that the scanner has it's own ground and gives the ECU a ground to start. So it sounds like you have a bad ground somewhere. The first one I would check is the main ECU one, which is the G101 ground on the back of the head. It's a huge PITA to get to, but it is possible. Make sure that is tight.
thanks suzuka. That ground behind the block is a PITA.
Utah- to be honest, it happened AFTER I messed with the negative cable on the battery. Issue with battery was it somehow corroded on a certain bend, so I snipped it and and reattached the wire to the connector
