wrong rear end?
Old 10-10-2006, 02:18 PM
importroadster's Avatar
Default wrong rear end?
OK, I have an 02 s2k and at 70 mph on the dash I am really going 77 mph using GPS as a guide. I know all about the whole using stock tires and how it can through it off but 7 MPH seems kind of high. I bought this car wrecked and I am suspicious that they may have put another rear-end in it causing the Speedo to be off. Any thoughts?
Old 10-10-2006, 02:55 PM
Ek9
Banned
Ek9's Avatar
Well, the stock dif is 4.10 ratio, as far as I know there are no higher ratios normally installed in the S2K dif, if it was a 4.57 or something lower, you'll be off on the opposite direction.
You're under 10% off. How different are your tire heights than stock? The other less likely thing is that it used to have a non-stock diff, it's got the calibrator on it to change the reported speed but, now has the stock dif in it.
Old 10-10-2006, 02:58 PM
SpitfireS's Avatar
What wheels and tires ARE you using?
Old 10-10-2006, 03:50 PM
Stock 16in Wheels, and 225/50/16 Bridgestone Potenza S-03 Tires on the rear.
Old 10-10-2006, 04:00 PM
camera obscura's Avatar
Originally Posted by importroadster,Oct 10 2006, 06:50 PM
225/20/16
So you're basically driving on rubber bands?
Just kidding. Typo I'm sure.
Old 10-10-2006, 04:22 PM
Slows2k's Avatar
Better recheck that tire size
BTW, 10% is AHM's acceptable speedo error
Old 10-10-2006, 04:43 PM
Opps sorry my bad! That would be 225/50/06
Old 10-10-2006, 05:15 PM
MattG's Avatar
Drive next to another stock s2000. Compare speeds.
Old 10-10-2006, 11:46 PM
SpitfireS's Avatar
importroadster Posted on Oct 11 2006, 12:18 AM
How and where was it "wrecked" ?
Check for a (leftover) Yellow Box / Jacket underneath the dash, close to the ECU.
Old 10-11-2006, 05:18 AM
SC_Highlander's Avatar
10% over is pretty close to what would be dialed in for a 4.57 gearset. I think I dialed in 11% on my yellow jacket. If the diff were replaced with a stock unit, without removing the 'correction', then this is exactly the type of speedo error that would result.
Quick Reply: wrong rear end?
